Guest Simon Posted June 18, 2003 Share Posted June 18, 2003 Here are some pictures of my VG30DET and 5 Speed gearbox which will be going into my 260z (the pics were taken with my roommates mobile phone) I ll have some better ones soon http://www.wn.com.au/simona/pictures.html Quote Link to comment Share on other sites More sharing options...
David K Posted June 18, 2003 Share Posted June 18, 2003 I remember when you first started your project. Good luck and take your time and have fun! Try not to lose too many hairs. Quote Link to comment Share on other sites More sharing options...
Dayz Posted June 18, 2003 Share Posted June 18, 2003 Good luck!! We'll be there for you when you'gonna try to pull your hair off Good luck!! Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted June 18, 2003 Share Posted June 18, 2003 Does any one know anything about the variable valve on this engine, and how to run it!! an info would be nice, there are photos of it on my website posted above Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted June 18, 2003 Share Posted June 18, 2003 I was just speaking to a mate and he was saying its either on or off so they can be ran on a duty cycle Signal ___________________ 00% __-__-__-_ 50% -------------------------- 100% etc... they run at 33Hz can anyone confirm this? Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted June 18, 2003 Share Posted June 18, 2003 good luck, I know a guy who spent nearly $12,000 to put in his VG30ET engine into his 280Z... due to the customization to get the engine mounted properly, he had to move the steering column around, cut the firewall to put the engine back further.. alot of stuff. good luck Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted June 19, 2003 Share Posted June 19, 2003 Im in Australia steering is on the right hand side turbo on the left, works out well. I know it will cost quite abit but i have a few mates who are fabricators and very willing to help so that should keep costs down. Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted August 8, 2003 Share Posted August 8, 2003 OK here we go!!! The motor is in!! and looks great! Used standard gearbod mounts too. The gear stick came up the middle of the standard hole and looks like the standard drive shaft is going to fit too. Exhaust is done 3inch from the turbo back, very few bends... ie no dump pipe of such the turbo sits low and the pipe runs back from there all on the same level (almost). flywheel is sitting on the floor waiting to be put in this weekend, clutch is on order will be here hopfuly tuesday all going well. I cant afford a decent intercooler as yet so it is staying non intercooled (standard) with standard boost. I will be installing the computer to run it soon too. i am going to use a Wolf 3D http://www.wolfems.com.au/home they seem to be very good value for money! and Australian too. should be looking at around 230HP at the wheels with the standard engine. (only mods are exhaust, air intake and computer) i will be posting some pics soon, I will do my best to keep you posted Quote Link to comment Share on other sites More sharing options...
