RB26240Z Posted June 18, 2003 Share Posted June 18, 2003 I was told the RB25gts tranny, and the 300 zx twin turbo have the same tranny with a different bell housing. Please adavise. Thanks. Quote Link to comment Share on other sites More sharing options...
BRAD D Posted June 18, 2003 Share Posted June 18, 2003 I think that is true. The guy (Rick) that makes custom motor mounts for the RB26 swap, used an 300ZXTT 5 speed. I think his HybridZ name is skyline240z ? Quote Link to comment Share on other sites More sharing options...
RB26240Z Posted June 18, 2003 Author Share Posted June 18, 2003 Thanks for the reply Brad, I'm wondering if I would be better off just getting a 300zx tranny with the GTS bellhousing or stick to the GTS tranny. Thanks. Quote Link to comment Share on other sites More sharing options...
BRAD D Posted June 18, 2003 Share Posted June 18, 2003 Well what do you have? an RB26 in a 240Z or do you plan on doing the swap? Or did you blow up your GTS 5 speed? The GTR AWD 6 speed bell housing might bolt up too. I think the t-case is just in the tail housing. So you might not need a GTS bell housing, ask Rick. Quote Link to comment Share on other sites More sharing options...
RB26240Z Posted June 18, 2003 Author Share Posted June 18, 2003 Iam doing a RB26 SWAP INTO A 72 240Z. Quote Link to comment Share on other sites More sharing options...
BRAD D Posted June 18, 2003 Share Posted June 18, 2003 What parts do you have? Motor? I think the guy I get my parts from will sell a GTS 5 speed for 1000$ and he should have some in stock in Reno NV. Quote Link to comment Share on other sites More sharing options...
Guest RPMZ Posted June 18, 2003 Share Posted June 18, 2003 It would be the easiest to use the R33DET GTS tranny. R33 GTS & GTR gear boxes have identical internals, however GTR gear box has transfer case therefore not suitable for a RWD application. Make sure you get the turbo GTS tranny, as the N/A one is much smaller. When making up a new tail shaft you will need the bigger yolk from the GTS turbo or 300zx turbo, which I had problems finding when I put an RB25DET transmission onto my L28T. Quote Link to comment Share on other sites More sharing options...
BRAD D Posted June 19, 2003 Share Posted June 19, 2003 And the GTR has one more gear, its a 6 speed right? Quote Link to comment Share on other sites More sharing options...
Guest RPMZ Posted June 19, 2003 Share Posted June 19, 2003 Only R34 GTR is 6 speed, I was comparing R33 GTS & GTR as parts would be cheaper. Quote Link to comment Share on other sites More sharing options...
Guest zline Posted June 19, 2003 Share Posted June 19, 2003 From what i've seen / swapped in for friends, the transmissions are the same save the bellhousing, however, making such a frankenstein transmission for a high power high stress application would raise question as to how long it'd hold, just something about hodgepodge that scares me with these cars. The best, and most tested, also simplest route would be to bang out/cut the tabs from the tranny tunnel and use the GT-S transmission. it bolts up and is strong as hell Quote Link to comment Share on other sites More sharing options...
