TunerCat now has a realtime tuner
Tim240z
I just Monday started the tuning process on my TBI system. It's a total hybrid motor - a 327 with a Holley 670 intake, single-plane, Comp 270 cam, Vortec heads, roller everything, five-speed, so on. None of the PROMs I found are even a good *approximate* starting point, especially with the cam. This thing may be a gigantic time-saver. The only downside I see is me running into a tree 'cause I'm looking down at the display at the wrong moment. Hey, maybe I can win a Darwin award! "Guy wanting to go fast ends up stopping fast!" I ordered a Romulator and the software anyway.
damn Mudge....where you been dude!
LoL... I am waiting for my MegaSquirt stuff, I have the electronics but am waiting for the Bowling/Grippo stuff to arrive. Its just flat depressing without it running, I dont know what "went wrong" with the stock setup. After I got another coil bracket from a member, I had spark! But no fire, I am only guessing not enough fuel pressure because there was a leak with one of my connections thanks to an incorrect thread.
So I gave up, ordered the MS and hopefully it will run, someday :roll: if not I'm going to get a freaking V8.
What's a "PCM simulator"?
Some Aftermarket tuners use these, its imply a hardware and software simulator of the real deal. Developers use these all the time, or sometimes the actual hardware hacked up and interfaced with a PC (Playstation developers, etc).
This is what allows the real time changes, since the actual PCM cannot do this, it has to be flashed from front to back which takes 3 minutes. The $EE PCM has two flash chips, the T and M chip, thats the only PCM I know because I have a 94 Z28. 93 and previous was a removable PROM, similar to most older cars.
Sounds like the Romulator (I just *love* that name, don't you?) is a system of this type. To use it you remove your existing EPROM and plug in the adapter, plug the box into the adapter, plug the PC into the box, load the Tunercat software with the appropriate mask and .bin files. Some of the guys at ThirdGen have reported that the changes take "a second or two" while driving down the road (or actually pulled over, I hope). One individual (ski_dwn_it) has a '7148 ECM (the $31 mask, very similar to my 7747 ECM w/ the $42 mask), posted (and note that he's using 2 laptops, which isn't necessary if you have 2 serial ports, and may not even be necessary if you have only one):
I would drive down the road, watch the other laptop's blms. Pull into a safe location. Make a change to the inj const, pull back out...drive/watch , pull in make another change....repeated the process for about 1 hr till [nearly every cell was] at 127, with one or two stragglers at 133.
Again tuned the starting tables so it fires nearly instantly.
All this was done without ever getting out of my seat. LOL
Once you've made changes to your satisfaction, you burn the finalized chip. Of course, you still need a burner and EPROMS and whatnot, but the Tunercat software saves a burn-ready .bin file. I've been struggling with a tip-in problem, and have managed to go too rich / too lean back and forth several times. Half of the problem is the long lead-time between changes - half an hour at the very least, usually the next day. I'm kind of sneaking up on it, but with one of these things I think I can zero in on it in a matter of a couple of hours. Plus, maybe get the idle stabilized....
It's possible to modify *any* of the variables in Tunercat, including:
ECM Switch Parameters:
Err 24, Vehicle Speed Error , X=Enabled
Err 32, EGR Error Enable, X=Enabled
Err 42, EST Diagnostic, X=Enabled
Err 43, ESC Error Enable, X=Enabled
ECM Constants:
Main Spark Bias
Initial Spark Advance
Extended Spark RPM Slope
Max RPM for Extended RPM Spark
Min. Speed To Enable Highway Mode Spark
Time Delay To Enable Highway Mode Spark
Bypass Power Enrichment Delay
Power Enrichment Mode Delay
BPW Constant
EGR On, (% TPS)
EGR Off, (% TPS)
EGR Off, (Speed)
EGR On, (Speed)
Low MAP EGR Off, (MAP)
Low MAP EGR On, (MAP)
Minimum MAP for BLM
Maximum MAP for BLM
Maximum RPM for BLM
Speed to Enable Open Loop Idle
% TPS To Enable Open Loop Idle
Maximum AFR At Open Loop Idle
Lean Idle AFR At Open Loop
Maximum AFR In Open Loop (Non-idle)
Warm Closed Loop Delay Timer
Cold Closed Loop Timer
Min. Coolant Temp. For Closed Loop Fuel
Open Loop Idle AFR Enable RPM Threshold
Open Loop Idle AFR Disable RPM Threshold
Open Loop Idle AFR Enable Delay
Open Loop Idle AFR Time Delay
TCC Lock, Low Gears, High Speed
TCC Lock, Low Gears, Low Speed
TCC Lock, High Gears, High Speed
TCC Lock, High Gears, Low Speed
IAC Park Position
IAC Park or Neutral Offset
Idle RPM Adder - A/C On
Maximum BLM Value
Minimum BLM Value
Minimum Integrator Value
Maximum Integrator Value
Stoichiometric AFR
PROM ID
Tables:
ECM Switch Table
ECM Constant Table
Main Spark Table
Cool Compensation Spark Advance
Power Enrichment Spark (Deg)
Highway Mode Spark Advance Vs. Vacuum
Max Knock Retard Vs. RPM (in PE)
Max Knock Retard Vs. MAP
Main Fuel Table #1, % Volumetric Efficiency
Main Fuel Table #2, % Volumetric. Efficiency Adder
% TPS Threshold Vs. RPM for PE Mode
Power Enrichment Air Fuel Ratio Vs. RPM
Accel. Enrichment Vs. Differential TPS
Accel. Enrichment Vs. Differential MAP
Open Loop Air Fuel Ratio Vs. Coolant Temp.
Air Fuel Ratio at Startup Vs. Cool. Temp. (Choke)
Open Loop Air Fuel Ratio Vs. MAP
Choke Air Fuel Ratio Multiplier Vs. Coolant Temp.
Crank Air Fuel Ratio Vs. Coolant Temp.
BLM Cell RPM Boundaries
BLM Cell MAP Boundaries
IAC Steps Vs. Coolant Temp.
Target Idle RPM Vs. Coolant Temp.
EGR Spark Advance Vs. % EGR
% EGR Vs. Load Vs. RPM
EGR Correction Vs. Load Vs. EGR Duty Cycle
BPW Constant Vs. Air Flow Vs. EGR D.C.
TCC Load Upper Limit vs MPH, (Low Gears)
TCC Load Lower Limit Vs. MPH, (Low Gears)
TCC Load Upper Limit vs MPH, (High Gear)
TCC Load Lower Limit vs MPH, (High Gear)
