i want an Oil Temp guage in my 240z
so im thinking its pretty easy right? just tap the oil pan with a bung and screw in an oil temp sensor and then wire it into the little autometer guage i install in the dash...right? but my REAL question is what oil temp sensor should i use? i need something small and easy to find, like maybe something from ford? anyone else done this?
suggestions greatly appreciated.
cheers-
Yanos
I put one in my LT1 (in my 240Z). I used the Autometer Ultralite electrical. Comes with everything you need except for some wire for the sender to the gauge.
I used a hole that already exists in the LT1 pan (for the low oil warning sender), but you're right, just drill a hole, thread in the fitting (with some good sealant), making sure that the sender is low enough to be in the oil.
Tim
