Guest Anonymous Posted July 4, 2003 Share Posted July 4, 2003 so im thinking its pretty easy right? just tap the oil pan with a bung and screw in an oil temp sensor and then wire it into the little autometer guage i install in the dash...right? but my REAL question is what oil temp sensor should i use? i need something small and easy to find, like maybe something from ford? anyone else done this? suggestions greatly appreciated. cheers- Yanos Quote Link to comment Share on other sites More sharing options...
jaime240z Posted July 4, 2003 Share Posted July 4, 2003 I'm pretty sure Autometer temp guages are a complete unit for mechanical temp guages. I believe the elec. temp guages come with senders too, but I would call summit racing or jegs to be sure. summit: 800-230-3030 Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 4, 2003 Share Posted July 4, 2003 I put one in my LT1 (in my 240Z). I used the Autometer Ultralite electrical. Comes with everything you need except for some wire for the sender to the gauge. I used a hole that already exists in the LT1 pan (for the low oil warning sender), but you're right, just drill a hole, thread in the fitting (with some good sealant), making sure that the sender is low enough to be in the oil. Tim Quote Link to comment Share on other sites More sharing options...
