Can someone with desktop dyno run my numbers?
I would really appreciate it if someone could run my numbers for me. I would buy the program but I dont plan on building another engine for a while so it would be pointless for me to buy it. I know I have asked for this before but I didnt have as much info as I do now. If you need more information please let me know!
1993 LT1 Chevy 350
BORE............4.030"
STROKE........3.480"
iNTAKE..........PORT MATCHED AND ENLARGE RUNNERS
HEADS..........LT1 HEADS PORTED(58cc)......#'s are flown @ 28in
INTAKE...100 @81...200 @145...300 @195...400 @234...500 @255...
600 @252...700 @252
EXHAUST....100 @58...200 @108...300 @149...400 @181...500 @197
...600 @206...700 @212
COMPRESSION.......10.9
INTAKE VALVE.......1.94"
EXHAUST VALVE....1.50"
58MM THROTTLE BODY....1000CFM
36LB INJECTORS
LT4 HOTCAM.....HYDRAULIC ROLLER CAM 1500-5500 RPM
INTAKE EXHAUST
LOBE LIFT............ .328" .328"
GROSS VALVE LIFT .525" .525"
LOBE CENTERLINE 109 DEG 115 DEG
DURATION @.006" 272 281
DURATION @.050" 219 228
ROCKER ARM RATIO 1.6 1.6
VALVE ADJUSTMENT 0 0
LOBE SEPERATION 112
VALVE SPRINGS........
OUTSIDE DIAMETER.....1.337"
INSTALLED HEIGHT......1.780"
SEAT LOAD.................101LBS
SOLID HEIGHT............1.215"
Thanks for whoever wants to help me out! :D:D
Guy
Yeah I just downloaded the free demo of DD2003 but I cant change all the stuff I need to do my engine. I wasnt sure if it would be a big hassle or not? Can you buy DD at like Best Buy? Or is it only sold through their website?
Guy
I guess I'm just curious what DD has to say? I will be able to get on a dyno near the end of August for free(theres a dyno at the tech school I attend and I was buddy buddy with all my teachers!) I didnt think it would be too much of a hassle to throw my numbers on DD thats all.
Guy
Guy, if you can tell me when your intake and exhaust valves open and close in relation to TDC I can give you some rough numbers! I'll email them right off the program if you like.
How can I get those numbers? Sorry I didnt get back right away, my computer was freezing up and I had trouble dialing up again. God I cant wait till I get a DSL connection!
Guy
Guest Phil1934
I used the cam tool for the numbers. I put the cam in 5* advanced as most are ground that way. not sure of yours. I got
RPM HP TQ
3500 265 397
4000 313 398
4500 329 384
5000 345 362
5500 345 330
6000 332 290
6500 305 247
If you want the actual valve events, go to http://www.prestage.com and hit downloads and cam files and see if it's in there. I'm not computer savvy enough to open it. But a small change in cam won't make any difference. Also I'm not savvy enough to download http://www.virtualengine2000.com a free program. Also there's 40+ HP lost in the muffler so add that in if you like, but these programs are better for comparing options than getting numbers.
