Guest Anonymous Posted August 4, 2000 Share Posted August 4, 2000 Hi guys, Any info on a Tremec 6-speed out of '98 LS1 T/A? I have a line on one with all the extras for cheap if I want it. I have a built 400 sb chevy pushing 400 hp, going into a '77 280z. Anyone put one in a Z before? Any info would be great. Thanks, Spanky Quote Link to comment Share on other sites More sharing options...
John Scott Posted August 4, 2000 Share Posted August 4, 2000 BorgWarner was recently acquired by Tremec. My aftermarket T56 says Tremec on the side, Rob's, same model, says BorgWarner. Perhaps this is one of the newer models made after the acquisition. If it has the 2.66 1st gear, should be good for 450 lb/ft. If its the 2.97 1st, good for 400 lb/ft. If you found one of these for a good price, then your lucky. They're usually pretty expensive. JS Quote Link to comment Share on other sites More sharing options...
pparaska Posted August 5, 2000 Share Posted August 5, 2000 The bellhousing for the LS1 won't fit the other SB Chevies Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted August 5, 2000 Share Posted August 5, 2000 Pete's right. Nice trans but it's designed specificly for the LS1 and I believe it's got a non-swappable integrated bellhousing on it. Input shaft may also be a different length. Some of the Chevy rags have had buildups using the T56 recently, if you get a chance try to pick up some of the issues of Hot Rod, Car Craft, or maybe Super Chevy and look for those articles.... Quote Link to comment Share on other sites More sharing options...
pparaska Posted August 5, 2000 Share Posted August 5, 2000 The August ? CHevy High Performance had a T-56 swap article that said the LS1 was difficult to swap to other SBC's Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 6, 2000 Share Posted August 6, 2000 Thanks guys, I did have the August CHP issue and it does mention the fact that the LS1 tranny and engine are a matched setup designed specifically to be used with one another. ...back to the search. spanky Quote Link to comment Share on other sites More sharing options...
