konig Monsoon Wheels
Nice choise of rims! I have them in a 17x7 though.
Universal means it will have 8 lug holes(for a 4 bolt pattern) One will be a 4x100mm pattern and the other will be a 4x114.5mm(I think its 114.5mm or is it just 114mm or is it completly different? :D ) Anyways heres a pic of my 17x7s(Monsoon rims!)
http://www.datsun-280zx-lt1.com/Big_Pictures/Body_and_Wheels/rim1.jpg
Hey Greimann did you use longer wheel studs on yours or are you still running the stock wheel studs to hold on the adapters? I thought you said you did but in that pic it doesnt look like?
Guy
Guest greimann
You are right, the studs are not all the way to the top of the nuts. They don't have to be. Technically, if you can put 6 full turns on a nut, that is sufficient thread engagement to make it secure. The picture shows a stock ZX front hub with a 1.5" thick adapter from Modern Motorsports. Everything works out fine.
