Dan Juday Posted July 20, 2003 Share Posted July 20, 2003 What's up with that? When I did the swap in my '73 it had one wire to the gauge. Now I'm doing a swap on a '78 and it has two wires. One goes through the firewall and the other goes to the batch of relays on the passenger side fender well. I only need the gauge to work. Do I need both wires? Both wires are yellow/black. Thanks, Dan Quote Link to comment Share on other sites More sharing options...
zcarnut Posted July 20, 2003 Share Posted July 20, 2003 One wire is for the oil gauge and the other wire goes to a switch inside the oil sending unit which closes once you have any oil pressure. This wire goes to a relay in the passenger kick panel that controls the fuel pump. So, if you lose oil pressure then the fuel pump is turned off. This is part of a saftey feature. If you have a accident and the engine stops running but the ignition key is in the ON position, you want the fuel pump to stop so as not to feed a potential fire. Before 1978 Nissan used a sense voltage from the alternator and/or a signal from the airflow meter to determine if the engine was running. However, it was shown that a fuel injected engine would operate even upside down, so a signal from the oil pressure sending unit was then used instead. Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted July 20, 2003 Author Share Posted July 20, 2003 Thanks Steve, This is what I had presumed but I wanted confirmation. Quote Link to comment Share on other sites More sharing options...
