Guest needwaymorespeed Posted May 15, 2002 Share Posted May 15, 2002 Whats the census on valves ferrea si or manley leaning toward ferrera thanks Curtis Quote Link to comment Share on other sites More sharing options...
Mike C Posted May 15, 2002 Share Posted May 15, 2002 I have Manley ProFlos in my Camaro and run on the street with super unleaded 12k miles (see post on roller lifters) with no troubles. Ferrea is well known, but pricey, correct? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 15, 2002 Share Posted May 15, 2002 Manley, hands down. Excellent quality at a reasonable price. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 15, 2002 Share Posted May 15, 2002 I have used name brand and no name valves in motors for years . When picking a valve I look for a couple of things . 1. A welded on hard tip 2. Chrome plated stems Then I look at what RPM I will run the motor at and how much spring pressure. So to answer your question , If the motor will see high RPM for long periods of time (6500 and up for 1 hr and more ) I buy GOOD valves , but if the motor Is driven on the street and sees stop light action or auto cross . I keep Spring pressures 110-120 on the seat and use A valve next step up from stock . Remember valves break for 3 basic reasons 1. To high of exhaust heat ( weakens the valve at the point just behind the head ) 2. Detenation ( Defroms the head ) 3. Valve float ( Piston Contact ) Good Luck TM Quote Link to comment Share on other sites More sharing options...
