warrenp Posted July 25, 2003 Share Posted July 25, 2003 from the fusible link box listed there is a BR and a R wires listed on the wiring diagram in the haynes manual. i think BR the wrong color code but any way the actual wire colors from the box are white/blue and a red wire that go to the ECCS where do they plug in to the eccs???????????????????? do they mate up to different color wires? if so where? i'm gonna change my user name to I HATE HAYNES any way as you can see i only have 3 wires left to plug in i would really be greatful for the help!!! Quote Link to comment Share on other sites More sharing options...
yo2001 Posted July 25, 2003 Share Posted July 25, 2003 what year? I got 87-88 FSM, I can look it up for you Quote Link to comment Share on other sites More sharing options...
warrenp Posted July 27, 2003 Author Share Posted July 27, 2003 it's a 87 wiring harness Quote Link to comment Share on other sites More sharing options...
yo2001 Posted July 27, 2003 Share Posted July 27, 2003 I thnk I got your problem solved now. BR and R wire comes from the fusible link but those doesn't go straight to ECU. BR goes to main relay (EFI relay) then B/W goes to MAF terminal E and R(from the main relay goes to ECU pin 6. Then R wire from the fusible link goes to safety relay. After that, goes to the body ground. I don't know if I ever used those. If you want I can send to the detailed diagram. Quote Link to comment Share on other sites More sharing options...
warrenp Posted July 29, 2003 Author Share Posted July 29, 2003 hey i really appericiate the help. hopfully tomorrow if i can make time i will plug her in and see what happins. i'll message you back asap when i get some results Thanks!!!! Quote Link to comment Share on other sites More sharing options...
