Rust on the on my Z car! Please help!
ASA240Z
Sand off all the paint from the entire panel, and check for rust on any of the other sections. If the rust is only in the one spot, cut it out and then cut a piece of sheet metal to the same size and weld it in. Then use some plastic filler and smooth it out, sant it down and primer and paint.
Where in CA are you?
Tim
Guest BigWhyteDude
um ok what is the diference in the serpintin system over the standard v-8 pully system?? Are there any advantages suck as less hp loss?
