Guest jeepxr400 Posted August 2, 2003 Share Posted August 2, 2003 I put this in the ignition section but nobody's there. So................. I've got a 71 240Z and when the key is put to the START possition A relay above the passengers "foot" clicks. No starter action. I thought it might be the solinoid so i put in a new starter(old starter was good). Same condition. I took a screw driver and bridged the "positive" and the "blade" on the starter, it works. I dont know anything about electricicty but is it the clicking relay at fault? I got good conections all around. Thanks, Forrest. Quote Link to comment Share on other sites More sharing options...
jaime240z Posted August 2, 2003 Share Posted August 2, 2003 I recently had the same problem. Look in the Troubleshooting Category for my thread. I think the title was Car won't start. Help with parts ID. I'll try to link it here..... Quote Link to comment Share on other sites More sharing options...
jaime240z Posted August 2, 2003 Share Posted August 2, 2003 See if this works: http://www.hybridz.org/phpBB2/viewtopic.php?t=23529 Quote Link to comment Share on other sites More sharing options...
Guest jeepxr400 Posted August 3, 2003 Share Posted August 3, 2003 thanks, i'm doin some research Quote Link to comment Share on other sites More sharing options...
GAZRNR Posted August 3, 2003 Share Posted August 3, 2003 Had a friend with a 78Z that had a similar problem. After replacing the starter he changed the battery cables and the problem was solved. The cables looked fine but when we cut one open it was all green corrosion on the inside. Quote Link to comment Share on other sites More sharing options...
Guest jeepxr400 Posted August 4, 2003 Share Posted August 4, 2003 I'll double check tues. If i can jump it at the starter, it has good cable power right? Quote Link to comment Share on other sites More sharing options...
