83 Turbo wiring diagram?
cygnusx1
Hey I am doing a Turbo swap into my 77. Do you happen to know what the magical 6 wires are that i need to hook up? I know that I have all the wires needed in the car. I just lost the paper of which wires I needed to hook up. Any help would be great.
Magical six wires? Lets see:
Coil
Tach
Water Temp gauge
ZX Fuel Pump Relay
ECU inputs
Fuel Pump Control Modulator inputs
Fusible link for Fuel Pump
Fusible link(s) for ECU
Jumpers to convert to the solid state alternator
Sheilded wires to ZX fuel pump
Power connection from fuel pump relay to air regulator
Somehow tie in the ignition switch....
I see lots of wires that need to be connected between the ZXT FI harness and the Z chassis already. Some of the above may be redundant and I am surely missing some. I am not an electrician by any means but I am just trying to cover all the bases. I bet its more than just six wires to get it all working right.
When I get it right I'll post a procedure or diagram.
Dave C.
:wink:
P.S. Thanks GrayZee for the diagram....huge help!
