Guest ZmeFly Posted August 5, 2003 Share Posted August 5, 2003 hell guys i have an 83 ZXT with the P90A head. i have what seems to be valve clacking but as i inspected the head as best i can, it seems that the lifters are all good. pulled all the lifters out and none of them seemed to bleed down over night. still held there pressure very well. what i did notice and this is with the rocker cover off. yes it did make a huge mess but i wanted to see or try to see what was going on, that the culprit noise maker is actually a rocker going bad. it seems that the lash pad is extremely warn, (engine has almost 180K on it) and it seems to be at times actually smacking the cam lobe once the cam rolls around its highest point. another thing i noticed is when the engine is cool it will not do the louc clacking but will once warm. there is always a slight little tick tick tick tick, but once warm and when im done driving and the car is cooling down it will become very loud, starting out softly at first the louder and louder, but then quiet right down again. i can also stop this by revving the engine. like i said before though there is always a barely audible ticking. can either warn lash pads and or rockers cause this? any insight would be greatly appreciated. thanks Quote Link to comment Share on other sites More sharing options...
Guest ZmeFly Posted August 9, 2003 Share Posted August 9, 2003 good thing, i found out what it was, fixed it, cleaned them all, replaced them. then let a tappet from one of the vavles fly off into the front cover Quote Link to comment Share on other sites More sharing options...
Idnevno Posted August 9, 2003 Share Posted August 9, 2003 hey i run a P90A head as well if you need some parts let me know and i will see what i can do... D idnevno@hotmail.com Quote Link to comment Share on other sites More sharing options...
