Cooling my VG30DET
Guest Simon
Im in the process of swapping the VG30DET into my 260z, will the stock radiator work, or will i have to get a larger one.
People have told me that the stock one is quite good.
I will be useing 1 or 2 thermo fans to assist in the cooling.
What is better one big one or two smaller ones. Do you want to cover the most area possable?
There are a couple of different stock radiators I believe, anyway the one with the most core rows would obviously be the best. For fans I used two, side by side. They (singly) came off a Camira or a Laser, can't remember which, and had their own metal shrouds.
Cooling may only be a potential issue, if using twin electric fans, on a hot day when constantly using a lot of power eg around a race track.
