Head bolts re-usable?
If the head was originally TTY(torqued-to-yeild) then you can't reuse the bolts because they have already been stretched to their limits. However if they are not TTY then you COULD reuse them but I still wouldn't.
I'm not sure about the datsun head and if they were TTY. I dont think they are so you should be ok. I think TTY is kind of a new thery behind torqueing bolts. If you plan to make some serious power then I would upgrade to som ARP bolts. If this is just a lightly modified turbo engine then I wouldnt worry about it too much.
How much is a set of head bolts?
Guy
I think I payed $60 or so when I bought them about a year ago. Should have just gone with the ARP's.... Summit has them for like $125....
Thanks for all the replies, I think I will actually try to get a little extra cash together and get the ARP's before the car goes back together. later!
~Kenny
Thanks for all the replies' date=' I think I will actually try to get a little extra cash together and get the ARP's before the car goes back together. later!
~Kenny[/quote']
You'll like the ARP studs. I used then last time I had to put on a new HG.
