Arizona Z
EvilRufusKay
I'll second reaction research. I have the subtle z body kit(not installed yet). The workmanship is top notch and John is a pleasure to deal with.
Chip
the kit contains front fenders, rear quarter panels, air dam, and hood. His website lists a rear spoiler but he no longer makes them. You can buy the whole kit or just the pieces you want. So it wouldnt be a problem to drop the air dam from the package. If your hood is in good shape I would think about dropping that as well.
Chip
Guest Willieboy240z
Mine has separate fiberglass bumpers. No rubber inserts.
Also, I have not decided exactly how (or if) I will be utilizing the openings. I first thought about putting fog lamps there, but now I am thinking of running ductwork to cool my brakes. Or, I might fashion a cold air supply for my carbs. This would be easy with FI...
Rufus,
the hood from Reaction research is fiber glass and has the vent cutouts like the 280's, for an extra charge he can glass over them to make it like the stock 240 hood. He offers two versions of the hood, stock and a "high rise" type, both are fiberglass. You can get the same spoiler from one of the other vendors but which one escapes me now.
Guest Willieboy240z
You can get early 240zflimsy fiberglass bumpers from zcarparts.com. I think I paid about $100 each for them. But you won't get them to mount on a 280 without a lot of work fabricating brackets and removing/customizing your current bumper brackets.
