540hp 383 in this month's Car Craft
Guest the_dj
1fastz
Member
Member # 1715
posted May 26, 2002 02:10 PM
ROFL grumpy
"its a grenade with the pin half way out.. cheap parts at that power level dont live long.. not to mention they left a TON of stuff out on the cost exspect to paya bout 5800 for a motor like the one they built" very true! and yes most magazine article leave out or just plain lie about the true costs, an example I find laughable is the magazine articles that show 600plus hp small blocks useing nitrous with stock cranks, rods, and cast pistons, true it can be done for 1 or 2 runs on a dyno but long term that engines bound to blow
  • Replies 46
Guest 1fastz
just a note dont atempt to make air bleed changes unles you are sure of what you are doing..
they are permanent changes unles you have a carb with screw in aibleeds.
you have to use a drill to enlarge them if its needed.. and if you need smaller that is a pain in the ass as you have to epoxie them shut then slowly dril up to the size you need.
they will realy pull extra power out of a engine but if you go the wrong way your screwed ..
You sound like Dave Emanuel with that advice :D .
I doubt I'd try it before I tried a bunch of other things first. One tip I got off of the Chevytalk board was to solder them shut and drill. A bit easier and softer than epoxy. Both would save the carb body though.
Originally posted by 1fastz:
2. simply jetted the carb until they had a good power reading and said OH ok its tuned.. Guess what you need to tune air bleeds in a carb to get the maximum out of it not just jets.
Why do you think you can pick up 30 or more horses by swittching to a good aftermarked carb like a bary grant etc vs a stock holley even when the cfm is the same between the two .
Air bleeds? I confess my ignortance. Could we get a little more info on these and how to adjust /tune the carb using these? Thanks
