zgeezer Posted August 30, 2003 Share Posted August 30, 2003 Has anyone out there attempted to mount front disks from a 1990 M30 on an early Z? I just eyeballed one in local JY. The rotors are large ventilated and mounted on 4 bolt hubs. The calipers appear smaller in bulk than the Toyoto V6 calipers in my garage, but the pads appear to be the same size. The junkie in charge tells me that the hubs should fit a 280Z... Hmmmmmmm. The rear disk brakes appear to use an emergency brake on the inside of the hub rather than actuate the rear caliper pucks. Finally, there is another posting stating that the M30 CV axles are shorter than the 280zxt axles. Is there any info out there. Is this a possible front disk brake upgrade that would not need the spacer rings of the Toyo 4x4 swap? gw Quote Link to comment Share on other sites More sharing options...
auxilary Posted August 30, 2003 Share Posted August 30, 2003 problem is finding parts for m30.... they're almost non-existant, i'm surprised you found one! Quote Link to comment Share on other sites More sharing options...
