Guest DaneL24 Posted September 3, 2003 Share Posted September 3, 2003 I'll probably be putting an electric cooling fan into my '71 240, and I have a question about the fan wiring. Now I know the fan is turned on and off by a thermoswitch...but do I simply put the thermoswitch inline with the electric fan motor circuit...or do I have to wire it so the thermoswitch activates a relay to turn on the fan...and the actual fan motor has a different power source that is routed through the relay. I know the fan motor uses up a lot of juice...just not sure I would want all that juice flowing right through the thermoswitch. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted September 3, 2003 Share Posted September 3, 2003 You are correct. You do not want the fan current running through the thermoswitch. Just run a relay off a fusible link or a high current fuse to the fan, and switch the relay with the thermoswitch off a normal source from the fusebox. I prefer to wire it through a non-switched source so I can run the fan with the ignition off. Quote Link to comment Share on other sites More sharing options...
