Brake Problem need help!!
I have a LS-1 78 280Z with Toyo 4 piston calipers, and in the rear i have drums. I replaced the Aluminum drums with cast iron off of a 510. I replaced all the Brake lines in the whole car and bled the brakes as per manual. I also replaced the brake master cylinder with a 2+2 master. (The old one was bad) :x
Problems -
When braking the system is really sensitive and tends to lock up the rears before the front. (Dont know if the fronts are working at all?)
How would i know if the stock PV is working? or locked in rear postion?
How can i prevent it from being so sensitive when braking? (can i adjust something?)
Will a PV help stablize the rear to front brakes?
Thanks for any help i can get!!!
