When do you need forged internals...
Hey guys, just ran my el-cheapo combo on Dyno2000 and here's what it says...
RPM HP (fly) Torque (fly)
2000 152 400
2500 195 410
3000 240 420
3500 289 434
4000 335 439
4500 374 436
5000 396 416
5500 402 385
6000 385 337
I picked this combo because
1.) cheap parts. This is with unmodified vortec heads and flat top pistons.
2.)flat torque curve up to 5000rpm. drops off a little by 5500, and then dies around 6000.
My question is, can i run this combo reliably at low to mid rpms with stock internals, or will i need forged pistons, rods, and crank to keep this thing from going grenade on me? I won't be twisting it over 5500, but i don't want to be stupid cheap, either. How long would stock flat tops, rods and crank last in this combo? Just fishing for opinions...
thanks
Bill
I'd think a stock cast crank, stock forged or PM rods, and cast or better yet hypereutectic cast pistons would be fine. Keep it out of detonation and below 6500 and I'd think those parts (if magnafluxed, prepped and assembled correctly) would live fine at those power levels.
heres a fairly simple test
(1) is the piston speed over 4000fpm (48000/stroke x 2 = 4000fpm piston speed RPM MAX LIMIT which should only be reached for an instant before shifting)
(2) is the compression ratio 11:1 or greater
(3)are you going to use over a 100hp nitrous shot?
(4)are you going to run the crap out of the car every chance you get and/or not use a ignition rpm limiter?
(5) will you exceed 6300rpm where valve float, especially hydrolic lifter valve float is likely?
(6) do you enjoy long smokey burn outs and catching rubber in each gear change
answer yes to one and you probably could use forged parts
answer yes to two or more and you NEED forged parts
labrat
keep the rpms at 5500rpm or less and you should get years of use out of that combo.
Well, the car is going to be a daily driver, so it's not going to see THAT hard of use. I might get on it a little, but i won't be draggin to hard. Just hurting some ricer feelings here in Austin on the highway... Thanks for the advice, i'm trying to keep fairly cheep on this combo, but I didn't wanna get stupid with it. I thought the low revs would be key in helping out the longevity of the internals, but I wanted to be sure. I'll just be sure to set the rev limiter low (around 5800) just to be on the safe side. Thanks a million, fellows! I love to take advantage of the tremendous amount of experience on this board...
Might I inquire what cam your using, those are nice numbers, 439 ft/lbs at 4000, I like that alot. Thanks. Oh yeah, as usual Grump, you waste no words, thats a great test for forged parts.
Regards,
Lone
That was an comp cams Xtreme Roller 270 (270/276 advertised with .496/502 lift) , just figured out it would be a little too much lift for the heads though, now looking at XE 262 which shows about 405ft/lbs@4000. Mebbe just cut the valve guides, though...
