Guest ON3GO Posted September 13, 2003 Share Posted September 13, 2003 yeah problem, atleast i think i do.. front is all done, just needs to put the brake lines on... but now im doing the rear.. took off the sruts to install the coilovers and tokcios and well one of the gland nuts are to small.. what am i gonna do? any ideas.. i have to get this car done by tuesday the latest! mike Quote Link to comment Share on other sites More sharing options...
Mikelly Posted September 13, 2003 Share Posted September 13, 2003 Contact Tokico and they will send you the right one... Explain the situation and see if they can overnight it. Or go dumpster diving at the local salvage yard and hopefully you will find one. Mike Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 13, 2003 Share Posted September 13, 2003 theres no way i can use the stock ones?? i dont even think i have the number for tokico.. crap ill go look. Thanks Mike.. mike Quote Link to comment Share on other sites More sharing options...
Mikelly Posted September 13, 2003 Share Posted September 13, 2003 YOu could shim it and use a stick one possibly to get you where you are going, but I'd recommend replacing them with the right ones sooner rather than later... Use a large washer to take up the additional space between the top of the insert and the cap if it is a loose fit to the top of the insert. Gland nuts obviously run in various sizes depending on the maker of the insert, and sometimes you can get lucky and find another that will work. You could also go to the auto parts stor for help... They sometimes have a miscelanious bind in the back! Mike Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 13, 2003 Share Posted September 13, 2003 ok ill do that, i gotta run to a autoparts store for some washers anyways so ill bring my coilover/ strut in and see if they have one that will work.. i didnt even check i might need two.. hmm. thanks man mike Quote Link to comment Share on other sites More sharing options...
