Guest Anonymous Posted June 19, 2002 Share Posted June 19, 2002 Ok, I've been reading a lot and thinking this one through. I have a 69' 327 to drop in my 72' 240. I've read so much about the T56 and the R200. Both are certainly great accessories for the V-8 conversion. Can anyone suggest a good alternative (better fitting) transmission? I don't want to spend a month cuss'n and bending my uni-body. Also - the R200. Good sources? Wrecking yards? This project will begin to happen when the snow flies. I want to prepare now. Thanks Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted June 19, 2002 Share Posted June 19, 2002 I really like the world class T5, which can be found in '88 and up Camaros and Firebirds. I'm running it in a ZX behind a ~400 ft-lb motor and have 50k trouble free miles on it. A stock one legger 3.7 R200 and street radials limit the amount of shock load that can be transmitted. If you want to bolt up drag radials and a LSD, better go with Tremec T3550, which is an aftermarket (stronger) version of the T5. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted June 19, 2002 Share Posted June 19, 2002 Longg, I am using the T56 with the LT1 and apart from cutting the oem cross member out, I didn't do any pounding. Also keep in mind that my project started out with a 700R4, then a 200 4R, now finally a T56. All fit withouts fits o' pounding. Tim Quote Link to comment Share on other sites More sharing options...
Phantom Posted June 20, 2002 Share Posted June 20, 2002 If you decide to go with the T-56 - that .5:1 6th gear is really nice - you'll probably want a 3.7:1 LSD R200. You can get them out of '88-'89 300ZX's. Wrecking yard is good source. Check the links & yellow pages. You can probably find a yard that specializes in Z's somewhere in your area. T-56 is a relatively expensive transmission but it basically is bullet proof and, after all, it is a SIX speed. I just love the idea. My '77 started out with a 4-spd. - then went to an '83 5spd. with 3.90:1 R200, now going to LS-1 with T-56 & 3.7:1 LSD R200 - 10 year project so far. Quote Link to comment Share on other sites More sharing options...
