Grumpy: Does this 355 need a 750cfm? vacuum or mechanical?
.030 over 350
TRW forged flatops (compression 9.2-9.6:1)
AFR 195's (stock port/bowl)
Perf RPM manifold
Comp XE268
shorty hedmans
dual 2.5 to single 3"
I have a Carter 625 vacuum, elec choke now. I'd like to know what the gains of a edelbrock/carter 750 would be on this engine and if its needed.
The 355 is in a 2500Lb 240Z street car that will see rare strip duty.
Im assuming vacuum secondaries would be a better choice, but I'd like your opinion on that also. The rest of the combo, if it will help your judgement, is a 700R4, 3.54 gears and a 25-26" tire.
Thanks for any input here
you will probably see a small gain in high rpm hp with a vacume secondary 750cfm carb but unless your willing to do other mods like a new cam,super victor intake and lower rear gears I would not bother, youll likely spend several hundred dollars for a 5-8 hp gain in only the high rpm range and a slight loss of streetablity with the change of just the carb. I personally would not do it on a daily driver. if you want to get an idea of what you might gain , install a 2" open center carb spacer under your present carb (take the hood off just for testing if it wont fit) youll get a good idea of what the larger cfm airflow will do for you, without the expence.
