cygnusx1 Posted September 26, 2003 Share Posted September 26, 2003 Will an 82 Turbo ECU function fine on my 83 Turbo Motor with 83 electronics Thanks, Dave Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted September 26, 2003 Share Posted September 26, 2003 Should... the connections are the same I know that I also know I took my motor out of an '81, and swapped over to an '82 wiring harness and ECU, but still running the '81, crank mounted CAS, and it all works fine together. It shouldn't all be compatible. I think the one thing that might make a difference... dont remember where I got this idea... but you may want to be careful about if the ECU was for a manual trannied car or an auto. But then again... I know poeple put manuals into auto cars all the time... so you'll probably be fine either way. Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted September 29, 2003 Share Posted September 29, 2003 since i put zxt motor in my 77 a few years ago i have had 2 ecus go bad.put in ecu from pick&pull.didnt care what year just plugged it in .always worked fine.i always buy the ecu and afm if i see them on a car at p&p.best to have spare parts on the shelf in the garage. Quote Link to comment Share on other sites More sharing options...
fl327 Posted September 30, 2003 Share Posted September 30, 2003 ive experimented with almost every combo of ecu and afm there is for turbo cars, all started up and went just fine, lots of spares, heck yeah. Quote Link to comment Share on other sites More sharing options...
