Guest Blazer406 Posted October 5, 2003 Share Posted October 5, 2003 I am contemplating trying to install a narrowed 9" ford rear and mini-tubbing my '73 240Z. Has anyone on the board done this? Mike kZ has got my heart pumping on installing a narrowed rear end. His pics appear to me that I could fab and do the whole thing myself. I have access to all the neceaasry tools and I can weld good as long as it is not overhead....... How much weight difference is there between a R200 complete rear setup and a setup like Mike kZ is running with a coil-over narrowed Chevy 12 bolt? How will a coil-over equipped narowed solid axle drive like on the street? All other things equal (tire sizes and gear ratios...... )how does a solid axle hook compared to the independant rear? Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted October 6, 2003 Share Posted October 6, 2003 I did fab everything myself. Not sure what the weight difference is, I think it's about the same. It drives great on the street. So far with drag radials I'm not hooking up yet. Next step will be drag slicks! , the good thing about it is I don't worry about breaking anything. Here is an old post, maybe it will help: http://www.hybridz.org/phpBB2/viewtopic.php?t=6870&highlight=balck+green+stripes+z+whos Quote Link to comment Share on other sites More sharing options...
Guest Blazer406 Posted October 9, 2003 Share Posted October 9, 2003 So far with drag radials I'm not hooking up yet I never had any luck with the drag radials on my S10 Blazer. I absolutely love my MT ET Streets. I think they are real racing slicks with a few grooves cut in them. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted October 10, 2003 Share Posted October 10, 2003 Mike, I think your problem is that you are probably unloading the rear tires too quickly. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted October 10, 2003 Share Posted October 10, 2003 You're probably right scottie, I have a buyer for my drag radials, and will buy slicks. Maybe I'll get traction now! Quote Link to comment Share on other sites More sharing options...
stony Posted January 19, 2004 Share Posted January 19, 2004 scottie, Your talking suspention right? what could he do to fix it? if of course he is unleoading too quickly? Soften teh suspention? change setting on teh bars? I'm getting so damn close to getting my car in teh shop to start cutting and welding i can taste it ;> Quote Link to comment Share on other sites More sharing options...
Turbo Meister Posted January 20, 2004 Share Posted January 20, 2004 I am contemplating trying to install a narrowed 9" ford rear and mini-tubbing my '73 240Z. Has anyone on the board done this? How will a coil-over equipped narowed solid axle drive like on the street? I am running a Ford 9" in my 72 Z with Twin Turbo 383 Chevy power. My Z has been back-halved with mini-tubs. Tires are 12 " wide Hoosier Street Slicks and they hook ( some of the time ). The key to a smooth ride with this setup is the adjustable shocks. On the street I adjust them to be soft and for drag racing I turn the adjustment knob to a hard setting. The adjustment is easy and only takes a few seconds. Another important factor necessary to hook up the tires under load is the proper setting of the 4-link on the 9". I'm continuing to experiment with different settings and hope to one day get it just right. If you drag race your Z in the 10 second or faster bracket you need a solid rear axle Hanns Quote Link to comment Share on other sites More sharing options...
Guest ozcheek Posted January 20, 2004 Share Posted January 20, 2004 Do you have any pic of the installation of the engine and turbos? How does the car go around corners? Thanks, Oz Quote Link to comment Share on other sites More sharing options...
