weber tb vs 240sx tb
Guest ZmeFly
which is better which would be easier to use which would be more fuctional down that line with upgrades and going with a stand alone fuel management system.
which would you buy and why?
thanks for any insight
i like the weber, but they are hard to find, thus expensive.
60mm is not so expensive, but when getting them factor 75 extra for a spacer. changing the linkage isnt hard at all. Id say 60mm from a later model stanza or 240sx would be the ticket for a standalone, since they use a true variable volt to throttle position tps vs. the early and zx two prong on and off switch style tps.
