Guest FinalRights Posted October 22, 2003 Share Posted October 22, 2003 I'm looking at a Datsun 280zx 2+2 and I'm gonna go with an l28et. Does anyone have some links that show some of the upgrades that can be done to the l28? I've seen the custom twin turbo set-up already ,and it makes me drool . I read somewhere about using rx-7 fuel injectors,Z31 Ecu upgrade aswell. I'm guessing a 300zxtt fuel pump would be able to be swapped in. Whats this rear end from the 280zxt with the r200? Just about anything that will help me understand and give some tips on modding the l28et would be appreciated. Quote Link to comment Share on other sites More sharing options...
DAW Posted October 23, 2003 Share Posted October 23, 2003 The R200 rear-axle set-up for the 280zxt uses CV jointed axles, while the non-turbo R200 had u-joint half-shafts. If you need a lower gear in the diff, get your R200 out of a turbo 200SX, as late a model as possible; or V6 200SX. Came as 3.90 and 4.11 from the factory. DAW Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted October 23, 2003 Share Posted October 23, 2003 The best thing to do is go to Turbo/Supercharger section and look through it there is more info in there than u can handle at one time . Ivan Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted October 29, 2003 Share Posted October 29, 2003 You can also find the R200 diff out of a 300ZX that has LSD, if you can find it. Quote Link to comment Share on other sites More sharing options...
