Guest Simon Posted October 28, 2003 Share Posted October 28, 2003 just on another note what temp should the water be coming out of the engine currently it sits at about 94`C and highest i have seen it is 98`C and cursing its about 92-93`C it that about right or a little too hot? also the thermostat is on the inlet side which i thought is odd because they are normally on the outlet side Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted October 28, 2003 Share Posted October 28, 2003 What do you mean the thermostat is on the inlet? It will not work there. Also the coolant exiting the thermostat should be only slightly warmer than the thermostat setting, probably 85C but maybe 93-94 is ok - I've never bothered to measure except using my dash temperature gauge. Then I never see it higher than 82C unless it's hot and my radiator heat soaks. Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted October 28, 2003 Share Posted October 28, 2003 i know the thermostat is ment to be on the outlet, but on my engine it is on the inlet for some unknown reason i would say the 300zx Z32 VG30 is the same the thermostat is on the inlet, before the water pump, it just doesn't make sense. Quote Link to comment Share on other sites More sharing options...
