onephatz Posted October 31, 2003 Share Posted October 31, 2003 i've got a '75 with a '82 turbo motor a fuel system in it. i'm a little cramped for space and would like to replace the bulky restrictive stock afm with one from a different car. is there another afm that reads out the same air flow signal as the stock. if not can you use a different afm and a Apexi Super AFC to get the proper voltages/resistances? any info would help thanks jesse Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted October 31, 2003 Share Posted October 31, 2003 I don't know if it will work but you could try any of the german cars that use bosch L-jetronic. They're probably all about the same size though. Are you having trouble with your air filter location? Quote Link to comment Share on other sites More sharing options...
onephatz Posted November 5, 2003 Author Share Posted November 5, 2003 yea I don't have too much room to install a air filter or a pipe w/ filter if I could subtract about 4" I could run a cold air intake. if not I'll have to try and mount some kind of filter to the afm. besides I want to be able to tune a little better when I turn up the boost. Quote Link to comment Share on other sites More sharing options...
