Lason Posted February 18, 2006 Share Posted February 18, 2006 Heres one even better for ya. Instead of getting vacuum from the exhaust which wont create much get you a electric smog pump off an LS1 motor. Run it to your valve covers and then run a catch can to the recieving hose off the smog pump. You will get more vacuum with that. Like stated years ago on this thread you will create a vacuum in your crank case and be able to spin better and if you build your motor with the intentions of using a pump you can run low tension rings and get even a little more power. I know plenty of V8 guys that run this setup and love it. Quote Link to comment Share on other sites More sharing options...
