Amps drawn from headlights
I believe the OEM headlights are 55 watt on high beam, which, if divided by 12 (volts) give the amps drawn per lamp, which is not much. If you upgrade to a higher wattage lamp, simply do the same thing again for each lamp's amp draw and then multiply times two for the "set".
There's a basic electronic formula you can use:
P= I * V Power = Current * volts
P= watts
I = amps
V = volts
You can solve for any variable:
I=P/V
V=P/I
for lights, you know the voltage and the wattage.
for an example, a 12V, 55W lamp:
A=55/12 ~ 4.5Amps
ifyou had a 30AMP light,
P=30 * 12 = 360 watts.
Guest greimann
so amps is equal to watts divided by current?
-Ed
No. Amps and current are the same thing. amps = watts / voltage.
The actual formula is P= I V , and algebraic variations thereof.
where:
P = Watts
I = current (amps)
V = Voltage
If the cooling fan in question is rated in watts, then divide watts by 12 to get amps.
See this link for more info on DC power: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elepow.html#c1
