creeking when at begining of acceleration and on turns
Guest Joe017
it have a '72 240z all stock.. and at the begining of my acceleration right when the cars rear drops down a bit i hear some creeking coming from the rear of the car.. this also happens on turns. this is probly a simple fix problem im sure. can anyone help me?
Its probably chassis flex. Often the interior panels in the rear of the Z will rub each other as the unibody flexes, giving sounds as you describe.
However, a littlle more description of the problem wouldn't hurt... are we talking sqeaking with driveshaft revolutions? Could be your diff, u-joints, etc. Best bet is to jack up the car, do an inspection of the rear, check u-joints, bushings, etc. If the sound is coming from the interior of the car though I'd suggest adding a cage/strut tower bar in the rear to stiffen things up.
Drax240z, it does sound like it could be coming from the inside of the car. it also creeks when in turning. so a strut tower bar would help me out... well, i am going to change the bushings and get a strut tower bar. if u recomend a specific type please let me know.
