MegaSquirtnSpark fired up (on the first try)
mobythevan
Guest bastaad525
speed limiters suck :sour:
Just another reason I love old cars :)
Moby - are you saying that if my little black box on the side of the coil ever goes bad (the stock turbo ignition module) that I can replace it with a $15 GM HEI module? Or is that something that only applies to people running MS&S? If it matters at all I have an '81 motor with crank mounted sensor, and am running an MSD blaster 2 coil. No MSD ignition unit at the moment the ignition is just stock right now.
  Quote
It depends on the signal from the stock computer, but if it is the wrong plarity it would be easy to invert it. At the moment I think it would work to replace the ignitor transistor with the HEI module. If I had the old setup with stock computer still in the car I would try it out, but its too late for that.
