Guest bastaad525 Posted December 1, 2003 Share Posted December 1, 2003 speed limiters suck Just another reason I love old cars Moby - are you saying that if my little black box on the side of the coil ever goes bad (the stock turbo ignition module) that I can replace it with a $15 GM HEI module? Or is that something that only applies to people running MS&S? If it matters at all I have an '81 motor with crank mounted sensor, and am running an MSD blaster 2 coil. No MSD ignition unit at the moment the ignition is just stock right now. Quote Link to comment Share on other sites More sharing options...
Tony D Posted December 1, 2003 Share Posted December 1, 2003 WOOHOO! That's the info I needed! You da man Moby! I'm off to download the files now. And off to autozone for that "hot spark" GM chip! Thanks a million! Quote Link to comment Share on other sites More sharing options...
mobythevan Posted December 1, 2003 Author Share Posted December 1, 2003 are you saying that if my little black box on the side of the coil ever goes bad (the stock turbo ignition module) that I can replace it with a $15 GM HEI module? It depends on the signal from the stock computer, but if it is the wrong plarity it would be easy to invert it. At the moment I think it would work to replace the ignitor transistor with the HEI module. If I had the old setup with stock computer still in the car I would try it out, but its too late for that. Quote Link to comment Share on other sites More sharing options...
