creaking rear sway bar bushings
Quick question about sway bar bushings. I replaced the front and the rears with uerathane bushings. The rear ones were real hard to seat. After I got them in ( with the use of a jack to push up the bar) I have noticed a creaking, clunking sound at the rear. Is this cause I had to force them in? Did I need to grease the connection to the rod? Is it because it is too tight that it is making that sound? I couldn't find anyone witha problem likw this in the seach. So I hope some one can help.
Thanks as always,
Kyle
Guest 240hybrid
My instructions that came with my MSA bars say to lightly coat the inside of the bushings with a Moly-Sulfide grease. I don't know what a Moly-Sulfide grease is, but contentrated Silicone grease is what came with my rear end/control arm bushings from MSA. I had some pretty bad creaks and squeels from my rear end after not applying enough grease, and all I had to do was apply some more to remedy the problem.
Chase
