how much torque to 10sec on 1/4
You have alot of things that you need to factor in before you get that torque/hp #..
Weight/traction are two that come to mind.
I hear that every 100lbs is worth a 1/10th
sec. in the qtr. mile...
I have not run my car in the 1/4 but based
on 0-60 and 8th mile times I am in the 11's
My car is not the lightest Z on the planet
because of the V8, heavy cowl hood, heavy
corbeau targa rs seats,and roll bar...
I am guessing it is around 2800 lbs and i weigh 180...
My motor is aprox. 475hp 430lbs tq....
Zach, here is a formula you can use to project HP based on ET, MPH and weight. Couple of things you need to know:
- The resulting HP number might seem low and that is because it projects HP at the wheels not the flywheel like most crate motors.
- You must be able to predict a fairly accurate MPH as that is the most important factor in computing HP. Remember, MPH is the true indicator of HP
- You also need to have an accurate weight for the car, including the driver.
(((MPH x MPH)/ET) * (weight with driver/1000)) / 9.1
E.g., you have a Z that weighs 2650lbs with the driver and you want to run 10.90 @ 122mph:
(((122x122)/10.9)*2.65)/9.1 = 397.6hp at the wheels. If you apply the 80% rule, that is 497hp at the flywheel.
Dream on.
Scottie
71 240GN-Z
http://www.mindspring.com/~vscott911/gnz.html
