Someone Please Help Me!!!
I am in the process of replacing my dash in my 80' ZX and I can figure out how to get the rear window defogger and interior light dimmer switches out of the old dash. How does the nob come off of those switches???? bonk.gif
Someone please help me!!! :D:D:D
I work at a junk yard, so I might be able to help... Look for a very small set screw, or push the knob in and turn (one direction or the other) 1/4 turn, or pull REALLY hard. Are you trying to get just the knob off, or is there a plastic plate bhind the knobs? I'm trying to remember how they look.... Sorry if this doesn't help. Good luck!
Also, sometimes there will either be a very small allen screw in the knob that can be removed; look at the bottom of the knob for the allen screw.
If it isnt an allen screw then there will be a tension spring that is accessable from the back side of the knob. Simply find a very small & slender flat head screw driver or pick with a 90* (degree) bend in it; press the 90* bend into the back of the knob & at the same time press downward; with your other hand pull the knob towards you. If the knob is of the tension spring type-it should slide off when you do this.
Dont force it; be gentle-dont want to break it while figuring it out.
Hope this helped.
Kevin,
(Yea,Still an Inliner)
