Guest 240Z_72 Posted August 21, 2002 Share Posted August 21, 2002 Looking over my recently purchased V8Z, I see that the fuel and return lines from the fuel cell all the way up to the carb, are all rubber fuel line. I understand this must have been much easier and cheaper, but is it safe? This is basically my weekend stoplight drag car, will never see foul weather, garaged kept, etc. If I keep an eye on the condition of the lines, is it okay to keep this system the way it is? Thanks, Kurt Quote Link to comment Share on other sites More sharing options...
Tim240z Posted August 21, 2002 Share Posted August 21, 2002 As long as the tubing is in good condition (not cracking or perishing) and is routed away from heat and is secure and not chaffing on anything, there's nutin' wrong with that. Just make sure it has support at least every couple of feet ('P' clamps or something). Tim Quote Link to comment Share on other sites More sharing options...
pparaska Posted August 21, 2002 Share Posted August 21, 2002 Just an FYI, NHRA rules say no more that 12" of rubber fuel hose in the entire system. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 21, 2002 Share Posted August 21, 2002 Spooled aluminum on a roll for fuel line, or braided $tainless $teel would be better (or even steel line) as far as long term durability. The new barbed fittings and hose is attractive to me as well. Rubber tends to weather and crack after a while of undercar heat and stuff. Hard lines will last far longer if you make sure they aren't next to heat sources and you properly secure them with rubber lined clamps. Just an opinion to be sure. Regards, Lone Quote Link to comment Share on other sites More sharing options...
