BEST offset for a 7.5" Wide Wheel on the front?
Then I'll opine that perhaps a 6mm offset pushing the wheel out will be that "perfect" number you want. I ran an 8" wheel that was virtually a zero offset and it gave me about 3/8" between the OEM springs, and the fender lip. But you will need to measure the clearance yourself knowing the specs on the tires you want to run. Potential interference will be with the tire, and not the wheel.
Terry
If your 8 with 0 offset cleared 3/8" between the OEM springs, and 3/8" to the fender lip.
Then a 7.5 with 0 offset would give me about 5/8" between the Oem spring and 5/8" to the fender lip.
So to go flush I have to move the wheel out 5/8" or 16.125 mm or -16 ET.
15x 7.5 -16 ET would this be flush to stock fenders?
I see alot of people ordering custom wheels but when I search I can't find specific data that tells me what fits perfect. I wish we could put togethter a wheel offset with photos data base on here it would be helpful before someone buys 2000 dooolla wheels and then has to buy spacers because they didn't get the measurement right.
That seems to be right.
The biggest fly in the ointment is the tires. You can take a handful of (in this example) 245/45R16 tires, produced by different manufacturers, and mount them on the same wheel, and the sidewall profile will be different with subtle (and sometimes not so subtle) section width differences. And the way a tire fits on a wheel can make or break whether it will rub the fenders if you leave little margin.
