s5fc3s Posted December 29, 2003 Share Posted December 29, 2003 Hello all, Question: Is it possible to have a rear wheel that is 15 x 8.5, offset = -7mm that fits under the stock suspension? with or without flares? (This means the backspacing is 4" based on the numbers above) Also, what size tires work with a 15x8.5 wheel, stock rear suspension? ----- Any help would be appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
johnc Posted December 29, 2003 Share Posted December 29, 2003 Search the site. Quote Link to comment Share on other sites More sharing options...
s5fc3s Posted December 29, 2003 Author Share Posted December 29, 2003 the problem isn't only the clearance issue. i think with 4" backspacing, it will clear the stock rear suspension. the other problem is who knows what size tire (still commonly manufactured and available) fits on a 15 x 8.5 wheel? my guess is 245 50 15, or 265 50 15. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted January 1, 2004 Share Posted January 1, 2004 If it really is an 8.5" wheel then the width (for backspacing) is 9.5". -7mm is about .25", meaning that you have 4.5" backspacing. If you are acyually measuring the width of the wheel (rim to rim distance), then 4" backspacing is correct. Quote Link to comment Share on other sites More sharing options...
