Ferd/289 Posted January 2, 2004 Share Posted January 2, 2004 The bellhousing tag on my T5 is missing. Is there a way to tell if its a WC or what gears it has etc. without tearing down? Ferd Quote Link to comment Share on other sites More sharing options...
blueovalz Posted January 2, 2004 Share Posted January 2, 2004 The tail housing should have an aluminum tag with the type of transmission stamped on it. These numbers will give you most of the information you need, then find a site on the internet (there are several) that will tell you what the number on your tag means. If you can't find any of the sites, then I've got some conversion numbers here once you find the number. Quote Link to comment Share on other sites More sharing options...
Guest buschj Posted January 2, 2004 Share Posted January 2, 2004 There should be an ID tag on the trans case. Use this to decode: http://ddperformance.com/Trans%20ID%20chart.htm Quote Link to comment Share on other sites More sharing options...
Ferd/289 Posted January 3, 2004 Author Share Posted January 3, 2004 Unfortunately the tag is missing. Unless its stamped in, I will take another look. Ferd Quote Link to comment Share on other sites More sharing options...
Guest kc280zx Posted January 18, 2004 Share Posted January 18, 2004 it will say WC right on top of the case clearly. Quote Link to comment Share on other sites More sharing options...
