ULISES Posted July 20, 2005 Share Posted July 20, 2005 Well i might not be the first one either. The thing is that i purchased my engine already.I would have to wait some time to start my swap. Hope to finish soon! This is going on my 77 280Z Quote Link to comment Share on other sites More sharing options...
240Z2NV Posted August 12, 2005 Share Posted August 12, 2005 Gene Culley is the Parts Manager for Fred Beans GM. He is a sponsor on LS1.com and/or LS1Tech.com He frequently offers 'specials' for a month-at-a-time seliing parts AT COST, and you merely pay normal shipping. I believe that he did the special three times last year. My recommendation for sourcing those new GM parts is to lurk on those sites for a while, register, then when Gene makes the posting under the sponsor board POUNCE! It saved mas280 big bucks, and though I am on a much smaller budget, saved me ALOT as well. Gene is also 'good people' and generally very professional in responding to inquiries. I have referred alot of people to him, and never gotten any negative 'bounceback'. Quote Link to comment Share on other sites More sharing options...
zardoz337 Posted August 13, 2005 Share Posted August 13, 2005 Yeah, I overstated the "Big Block" idea a lil' bit, but just in terms of the sheer cubes is cool. The link had me laughing....there isn't even a price yet. If you have to ask, then you can't afford it! well they have a price now its $13.595 but look what you get..... LS7 specifications: Part number: 17802397 Horsepower: 500 (373 kW) @ 6200 rpm Torque (lb.-ft.): 475 (644 Nm) @ 4800 rpm Engine type: Cam-in-block 90-degree V-8 Displacement (L/cu in): 7.0 / 427 Bore x stroke (mm/in) 104.8 x 101.6 / 4.125 x 4.00 Block: Cast aluminum with pressed-in cylinder sleeves and 6-bolt, forged steel main bearing caps Crankshaft: Forged steel Connecting rods: Forged titanium Pistons: Cast aluminum Camshaft type: Hydraulic roller, 15 mm (.591 in) lift (intake and exhaust) Cylinder heads: CNC-ported aluminum; 70-cc chamber volume Valve size (mm/in): 56 / 2.20 (titanium) intake / 41 / 1.61 (sodium-filled) exhaust Compression ratio 11.0:1 Rocker arms: 1.8:1; offset (intake only) Recommended fuel: Premium required. 91 octane minimum LS7 crate engine (P/N 17802397) includes: Intake manifold with injectors Injector wiring harness Fuel rails Throttle body Dry sump oil pan Exhaust manifolds Flywheel & clutch Harmonic dampener Water pump and pulley Coil Packs, spark plugs and wires Engine sensors LS7 crate engine does not include: Dry sump oil lines Dry sump tank Engine beauty cover Engine processor Air filter/air box Accessories or accessory drive all I can say is......drool....... Quote Link to comment Share on other sites More sharing options...
peej410 Posted August 15, 2005 Share Posted August 15, 2005 i just wanted to mention that its been verified by magazines like car craft, that the crate ls1 motors make more then they are rated for by quite a bit. i wouldnt be too suprised if a crate ls6 makes more than an ls6 that comes out of a vette. Quote Link to comment Share on other sites More sharing options...
