Pertronics Ignitor Electronic Ignition
Guest Zachb55
Guest Zachb55
http://216.65.58.60/Merchant2/merchant.mvc?Screen=PROD&Store_Code=FAPWAP&Product_Code=1761
anyone ever heard of that or used one? not sure if its a better option then the XR3000. i know it costs a lot less and that it supposedly doesnt have the "black box" to "clutter your engine bay" as they put it. so whats the common feeling on this thing? any ideas?
-Zach
I use one inb my megasquirted 1977 260Z. It works perfectly. When I used to time my ignition I could see the timing mark on the pulley jump around. Now with the pertronix it is steady as a rock. Installation is 5 minutes. I got mine from this place. good and fast service. I accidentaly ordered the wrong (low performance) coil. They guy emailed me the next day that he would send the better one if thats ok with me. Great. I like to see vendors that think.
http://www.vintageperformance.com/retrorockets/Datsun/nissan.htm
Guest Zachb55
thanks for the info, what exactly will changing over to this do to my car? is it just a general upgrade sort of thing? i mean i know it replaces the points, but how come this thing can do the same job as a Crane Cams unit without the black box?
-Zach
With the pertronix you can bypass the ballast resistor on the coil. This (together with an other coil) can increase the output to the sparkplugs. I didn't feel a difference between the points and the pertronix. Although I'm glad I changed them because. This is a typical "install and forget" upgrade. You don't really notice it but you don't have to worry about it either. Also I'm thinking of going megasquirt&spark. It is nice to have a more accurate spark so that the computer timing is better.
I replaced my points with the pertronix because I was getting misfires at higher rpms. It turned out to be the injectors being too small.
I don't know anything about the crane unit, sorry.
Guest Zachb55
ahh, thanks for the tips, i think ive got the ignition working a little better now. i really need to get the carbs tuned some how though.. i think im going to start asking around to see if anyone around here has a synchrotester... i would like to use a colortune also... but these are different questions for a different area. thanks again for sharing your experience.
-Zach
