BAlford Posted September 1, 2002 Share Posted September 1, 2002 This has happened twice. The first time I was at a loss, but someone on Hybridz solved the problem for me. The brake lights would not go off. What happens is that there is a small button on the brake pedel that after time gets old and breaks from the presure of the brake switch. When this happens the brake light switch goes through a hole. You will find the broken button in the floorboard. It has happened on the car that I have now. I haven't fixed it yet. The last time I used some weather strip glue on a penny to fix the problem. Quote Link to comment Share on other sites More sharing options...
labrat Posted September 3, 2002 Share Posted September 3, 2002 Yeah, it happened to me too. Same solution as well. Used jb weld to glue a penny to the pedal. Worked great for 2+ years! Bill Quote Link to comment Share on other sites More sharing options...
Phantom Posted September 4, 2002 Share Posted September 4, 2002 I just used a 1/4-20 bolt & nut and tightened them up through the hole. That has worked for me for about 4 years now. I keep telling myself I should go by a wrecking yard and pry 2 or 3 out of some wrecks. Quote Link to comment Share on other sites More sharing options...
