Guest Max383 Posted January 17, 2004 Share Posted January 17, 2004 well i got a problem. i'm converting my z to to a v8 but i ran into a set back. i need new bushings and a new sway bar but i can't identify what year model my z was. the title says 260z 1974 but there are no vin numbers on car. the person i bought the car from said he converted the car to a 2.8 liter but wasn't really sure what the origanal car was since he bought it off someone else. next, the metel plate on the door that tells the car's wieght say 1973 for the year, but the dash board i took out says 260z. so you see my problem. is there any way to tell for sure what year model my is, and if not will the bushing and sway bar year really matter? Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted January 17, 2004 Share Posted January 17, 2004 what tail lights do u have? and what front turb signals u have? that will tell u if its a late 260Z and early. if he converted it to a 2.8 then it cant be a 280Z. so if its a 260Z its a 74. mike Quote Link to comment Share on other sites More sharing options...
Guest Max383 Posted January 17, 2004 Share Posted January 17, 2004 this is my first z, whats the difference in the lights Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted January 17, 2004 Share Posted January 17, 2004 Turn signal lights betweeen the headlights in top grill = late 260/280. If thery are at the corners under the bumper early 260 or 240. Quote Link to comment Share on other sites More sharing options...
Guest Max383 Posted January 17, 2004 Share Posted January 17, 2004 well my z has no turn lights installed and the has an after market air dam, any onther way to tell Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted January 17, 2004 Share Posted January 17, 2004 well is there brackets in where teh grill is? or is there holes for the turn signals by or in the air dam. any pics? it would be easier for us mike Quote Link to comment Share on other sites More sharing options...
jimzdat Posted January 18, 2004 Share Posted January 18, 2004 On all 4 of the Z's I've owned, the VIN was stamped on the firewall, above the brake booster--might be hard to see if it's all gunked up, but that will help figure it out as well Quote Link to comment Share on other sites More sharing options...
z-REX Posted January 18, 2004 Share Posted January 18, 2004 resident 260 expert chiming in.... taillights... if the backup lights are separated from the taillight.... it's not a 240, either version 260 or a 280. i have an early 260, build date 8/73, i think. also... do you have a title or any other paperwork with the curb weight? mine says 2425... i don't think any 240's went above 2400. build date's probably your best clue if you really can't tell where the turn signals in the front ever were. the taillights can separate a 240 from a 260/280, but without the turn signals and build date i couldn't tell you if it's an early or late 74......bob Quote Link to comment Share on other sites More sharing options...
Guest Max383 Posted January 18, 2004 Share Posted January 18, 2004 will it really matter about the version year of sway bar i buy is there really that much difference? Quote Link to comment Share on other sites More sharing options...
