Guest Drewz Posted January 25, 2004 Share Posted January 25, 2004 I have a chance to get some firehawks but they are 255/60/15's.Should I hold off to find 50's or will 60's be short enough??? Need to know soon. Quote Link to comment Share on other sites More sharing options...
Sparky Posted January 25, 2004 Share Posted January 25, 2004 check these out for comparison, http://resizeme.com/index.cfm?pg=browsealbums&albumid=274 they are 50s[/img] Quote Link to comment Share on other sites More sharing options...
Guest Drewz Posted January 25, 2004 Share Posted January 25, 2004 Rim size? Width? 245? 255? I am running ZG's so I want to go 9 inch rim. Quote Link to comment Share on other sites More sharing options...
Sparky Posted January 25, 2004 Share Posted January 25, 2004 rims size is 14x7 tire size is 265/50/14 Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted January 25, 2004 Share Posted January 25, 2004 255/60/15=27.1" diameter=too tall... stock~24.6" Want to stay near stock diameter. JTR says 235/60/15's will work=26.1" 245/50/16=25.1" 225/50/16 =24.9" 245/45/16=24.6" You sau you have 15" wheels - if they are 6", go 215/60/15=25.2" Lots of good ones to choose from in this size. If you have wheels wider than 6", say 7", you could run 225/60/15 =25.6".. I NEVER use the narrowest rim for a tire size in the manufacturers specs because handling is compromised. I stick to the middle, or preferably outer (largest width wheel). If this is a drag car only - no prob, if you like going around curves - do yourself a favor. JMHO of course.... Quote Link to comment Share on other sites More sharing options...
Guest Drewz Posted January 25, 2004 Share Posted January 25, 2004 9" rims are going on it. Hmmmmmmm........ Thanks guys!!!!!!! Quote Link to comment Share on other sites More sharing options...
