Guest dawg95_2000 Posted January 27, 2004 Share Posted January 27, 2004 Will the 280zx tranny work with a 300zx engine? Modifications or non? Quote Link to comment Share on other sites More sharing options...
frank280zx Posted January 27, 2004 Share Posted January 27, 2004 what 280zx tranny BW might work, i know the clutches do! Quote Link to comment Share on other sites More sharing options...
Guest dawg95_2000 Posted January 27, 2004 Share Posted January 27, 2004 its a '79 zx standard. Quote Link to comment Share on other sites More sharing options...
warrenp Posted January 27, 2004 Share Posted January 27, 2004 nope will not bolt up. the input shaft is the same clutch will work, on any z, 240sx all pickups 2.4 or 3.0 Quote Link to comment Share on other sites More sharing options...
technicalninja Posted January 28, 2004 Share Posted January 28, 2004 The VG30 and L28 engine have vastly different attachment bolt patterns. Easier to find the correct transmission. You would have to make a bell housing adaptor and then have to modify the clutch to work with the adaptor. One exception to the rule (maybe?) is the T5 out of the 280ZX turbo and the T5 out of the 84-85 300ZX turbo. These transmissions have removable bell housings and as long as you had the correct bell housing for the block the trannys might work. Have not heard of anyone doing this but it might be possible. Quote Link to comment Share on other sites More sharing options...
